First post, by cyclone3d
Finally have enough stuff to put together a dual Tualatin 1.4Ghz build.
The board I have has onboard Rage XL video.
Slots available are 5x PCI and 1x ISA.
It is going to have Windows 2000 on it and maybe dual boot to DOS/Win98SE.
Not sure if I am actually wanting to make it a gaming/workstation build or just a workstation.
Either way, here are the cards I am planning on using, which will leave me with 2x PCI and 1x ISA.
1. Frontier Wavecenter PCI (digital audio and MIDI interface card)
2. Gadget Labs Wave 8-24 PCI card with the SPDIF daughter card. Basically.. SPDIF in/out 8 regular audio in/out as well as a MIDI in/out.
3. Promise Fastrak S150 SX4-M PCI SATA RAID card
For 3d video I was thinking maybe a V3-2000 PCI
For audio I could use either PCI or ISA or both.
PCI would probably be a Yamaha YMF744 based card. Or I could even install my Yamaha SW1000XG but I was kinda thinking about putting that in a mainly gaming build.. but since this is going to be a workstation, I might want to just go ahead and use it in this.
ISA - I have a bunch of different stuff.. probably something with real OPL3 if I have anything that isn't speed sensative.
Or maybe I should forgo the Frontier Wavecenter card and use both a YMF744 card and the SW1000XG which would mean I wouldn't need an OPL card in the ISA slot.
Thoughts?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 1 of 13, by luckybob
Honestly a V3 is a good choice. You will have a hard time finding a better card. MAYBE an newer pci card like an ATI 9200? But honestly a V3 sounds pretty good for this case.
Reply 2 of 13, by nforce4max
^This enough said
Reply 3 of 13, by brostenen
V3 will give out some serious heat on this build, so you will have to add a fan to it.
Another way to go, would be to use V2-SLI.
Eighter way, V3 or V2-SLI you might only see performance differences when benching.
How about TNT2-Pro-Pci anyone? How well does it perform compared to V3-Pci? How about G400-Pci? (If ever produced)
Reply 4 of 13, by lazibayer
brostenen wrote:
V3 will give out some serious heat on this build, so you will have to add a fan to it. […]
I think people favor voodoo series for the love of voodoo. Pure performance-wise TNT2, G400 and V3 will all bottleneck tualie dualie. V5-5500 would be a better fit if the OP has one and is willing to dedicate it to the build. More realistically I would put an FX5500 PCI in it.
Reply 5 of 13, by cyclone3d
I mounted an 80mm fan above the PCI slot for the V3 in order to keep it cool, but I should have a couple PCI Quadro FX600 cards by tomorrow. Those are just about the same exact as an FX5500 and would leave me with the V3 for a pure gaming build.
I've also got a fake PCI FX5500. It is marked FX5500, but under the heatsink is a FX5200 GPU.
I don't have a PCI V5-5500. I have 2x AGP ones, but that doesn't help me. And I am not paying some ludicrous price for a PCI V5-5500.
YMF7x4 Guide
Reply 6 of 13, by lazibayer
FX600 is great, too. This is kinda workstation build and Quadro is a workstation card, so it's even a better fit IMHO.
Reply 7 of 13, by brostenen
How about some GF2-PCI (non-MX) then? I remember Creative made those back then. I have no idea if that would be better than V5.
Reply 8 of 13, by ODwilly
Pic fx5200 would be pretty good.
Reply 9 of 13, by lazibayer
They are slower than V5.
Reply 10 of 13, by kev
zotac has nvidia 520 and 610 pci cards just fyi https://www.geek.com/chips/zotac-launches-pci … ystems-1425207/
hard to find now and not cheap there is also another option and thats to use a pci to pci-e adapter like this https://www.amazon.com/StarTech-com-Express-A … 1/dp/B0037ECAM2
you can either get a pci-e 1x card or cut the back of the pci-e connector and use a full 16x card or use a 1x to 16x riser
im using a hd3850 in my dual tualatin but thats agp
Reply 11 of 13, by agent_x007
PCI options with DX9-DX11 support : file.php?id=37228&mode=view
Card list : Radeon 9250/X1300/HD 2400 Pro, NV GF 5500/6200/9500 GT/GT 610
Zotac's GT 610 is cooled passively (silent, no fans that can go bad), but heatsink can prevent installation of other cards in PCI slots nearby.
Sparkle did GT 610 PCI with active cooling (single slot).
Reply 12 of 13, by cyclone3d
Well, I do have some other/newer PCI cards.. but I wasn't really planning on using any of them in this build
Geforce 8400GS, GT 520, GT 610
ATI 9250, HD3450, HD4350
I really want to get these PCI cards.
Geforce 8500GT, 9500GT, GT 430,
but they are super hard to find at a good price. I saw a GT 430 a little while ago and should have snagged it before it sold. 😢
I do plan on getting a PCI to PCIe x16 adapter and a riser cable that also includes a power connector for another project.
From what I have seen with the PCI to PCIe adapters is that they work but looks like it leads to the video output having banding.. possibly due to not enough power and of course it is going to majorly limit the speed of faster cards.
YMF7x4 Guide
Reply 13 of 13, by kev
think im gonna do one more mod to my dual think its time to add water cooling been using full copper heatsinks on it all these years they did get it to 2ghz though 🤣 but not fully stable on everything 1.8ghz was always rock solid
