First post, by c0d3r3d
Hey all,
Picked up a cheap ThinkPad 600 in...okay condition off eBay a little while ago. Fixed the 161, 163, 173 errors it was having with a nice fresh CMOS battery but now I can't actually get the thing to boot off the HDD.
The drive that came with the machine is toast - I plugged it into a spare PC and HDSentinel for DOS reported a <30% drive health with many, MANY bad sectors. So that's out. I have a nice 100% IBM Portable Deathstar drive that I popped in there, and while the system detects it (and even passes when you perform a hard drive test), no matter what OS I use I can't get it to have any partition changes persist.
I booted up an XP CD to see what was going on, since 98SE wasn't showing me anything useful. The drive is reported as 8GB, which is already wrong, and no matter how many times I make a partition of any size, it just flatly refuses to make the change. The hard drive makes little skittering noises as if it's doing so, but nothing changes on screen.
I have tried MANY different overlays, OnTrack 9 (IBM OEM), Ontrack 4, and Maxblast, and only ONCE did it ever boot off the drive. After I removed the drive to copy over the 98SE files, it stopped booting from it again (it always throws an i9990302 error). Whenever I run one of the overlay programs off the ThinkPad, the firmware name of the HDD is always corrupt. I can never successfully install a drive overlay on that system - I have to do it on another and then transplant it.
At this point I'm not sure if the IDE controller is faulty or if there's absolutely no way I can get the 20GB drive to run on it (despite people saying they've done it before). Is there anything else I can try before throwing in the towel and getting a small CF/SD card or 6.4GB HDD? The BIOS is on the latest revision. I have a 527MB HDD out of an old Toshiba Satellite 100CS, but that thing just makes horrible grindy noises and halts the BIOS so that thing's long past dead.
Thanks for your help,
Aidan.
