First post, by moawkwrd
So I recently took ownership of two old computers (three actually, but one was just used for parts for the other two):
A Gateway G7-500, with a Slot 1 Pentium III Katmai 500MHz, 256MB PC100 SDRAM, 10GB Seagate HDD, Voodoo 3 3000 PCI 16MB, running on an Intel WS440BX motherboard with a nice Creative ES1373 sound chip, in a charming non-ATX minitower case.
And a Danner IT Systemhaus, with a Socket 370 Pentium 3 Coppermine 1000MHz, 512MB PC133 SDRAM, 40GB Maxtor HDD, GeForce FX 5200 128MB 64bit, running on a QDI Advance 10T motherboard in a lovely beige Chieftec case.
Benchmark results below:
3DMark2001SE:
Gateway=961
Danner= 4108
3DMark2000:
Gateway=2390
Danner=5362
3DMark99MAX:
Gateway=3882/7759
Danner=6145/14669
PCMark2002:
Gateway=1271/1065/142
Danner=2606/1692/810
I actually recently purchased a GeForce 4 MX 440 64MB 128Bit to compare with the FX5200 and the FX5200 actually comes out on top, just, in a variety of benchmarks which surprised me a little as I always thought the GeForce 4 MX440 was the faster card? I ran 3DMark2001SE quickly with it in earlier on the Danner machine and it scored 4038 compared to the FX5200's 4108.
Now I'm wondering what I could replace or add to make these two machines even better. I'm using them both to play a variety of games at the moment, but I also have a separate Windows XP machine (Core 2 Duo E6600, 2GB DDR2, GeForce 8800GTS 320MB) for mostly DirectX 9.0 games and above. The Gateway is my DirectX 6/7 & Glide machine I guess, whilst the other is more of a DirectX 7/8 machine. Is there anything I could do with upgrading these or are they pretty much spot on for their intended usage? I know the FX5200 isn't period correct as it were but it came with it so I might as well keep it.
I've had a look on eBay and GeForce 3s and 4 Tis are nowhere to be seen. Electromyne have some GeForce 4 Ti 4200s but I'm thinking they're more of a Pentium 4/Athlon 64-era card. I was actually bidding on a boxed GeForce 3 Ti 200 today but someone else wanted it for more than I was willing to pay. 😒
I have a couple of SCSI drives at home I think so I might try those out on the Danner machine under Windows 2000 as the third machine I used for parts came with an LSI SCSI controller card.
So are there any areas of either machine that you'd look to upgrade?
Xeon E3-1241v3 - 16GB DDR3 - Vega 56 - W10
PII 450MHz - 256MB SDRAM - Voodoo 3 3000 PCI - W98SE
