First post, by peew
peew
Offline
I'm trying to get the sound in X-com Apocalypse to work. When I choose to start the .exe file with VDM, it works fine. problem is that I have to setup the sound first. And when I try to run the setup with VDM, the setup program doesn't start. it just says that the VDDloader was successfully loaded, and then nothing happens. what should I do?
