First post, by keenerb
At some point I stumbled across a method for running Dosbox under actual MSDOS, using some sort of windows 32-bit console support library.
Is that actually possible, or did I hallucinate the whole thing?
Reply 2 of 15, by Jade Falcon
Rank BANNED
BANNED
To Emu old hard ware on a new system? 😕 Or just for fun?
Anyway I have seen a *inux Live CD floating around on the net that uses DosBox as the use interface or something to that effect.
EDIT:
I have seen people install MS-DOS in dosbox
http://www.transmissionzero.co.uk/computing/i … sdos-in-dosbox/
Reply 3 of 15, by DosFreak
You're looking for HXRT. Last time I tested a couple of years ago performance was pretty much the same in DOS as it was in Windows but this was a P166 so DOSBox was slow either way.
Re: Bored? Try running Qemu inside of DosBox using HX Dos Extender and HXGui
Point would be to run games on the computer that are too fast on the host or if something about your hardware or software configuration prevented the game from running then DOSBox would work.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 4 of 15, by keenerb
mrau wrote:
and the reason for this exercise would be what?
To see if it works?
I'm curious if my AMD 5x86/133 running DOSBOX could better approximate an old 8088 system than you can normally achieve simply by disabling cache/etc.
Reply 5 of 15, by .legaCy
My P4 build that runs windows 98 has issues with SB16 emulation so dosbox serve the purpose of solving this issue.
Also for speed sensitive games, so my windows 98 has a "extended range" on retro gaming.
Useful links
[ How to Multiboot any OS | Rebuilding GOG Installer for Win9x | 486DX-4 Build | S7 Time machine Build |
twitch stream (in portuguese)
Reply 6 of 15, by DosFreak
Did some tests with my compiled SVN of DOSBox (still a WIP)
Post 617752
Reply 8 of 15, by Malik
I'm not really interested in Dosbox running under pure DOS, unless I want to make any new modern computer behave like a DOS machine, by booting directly into DOS and Dosbox subsequently. But then, I could simply use the appropriate OS - Windows/Linux/OSX to do the same, by loading the respective native Dosbox build without unnecessary complications or headaches.
And I believe most computers or laptops available today are able to run Dosbox comfortably, to run any speed-sensitive games more conveniently.
BUT, just wondering... so Dosbox in pure DOS can make use of any PCI or ISA sound card or on-board sound chip to produce sound? Like in Windows? If so, how does it do that? I thought Dosbox can only do this via Windows' API. Does Dosbox probe for sound devices in pure DOS? Or it behaves like a dos game itself, by detecting the drivers loaded? How about for machines that have the original SB/SBPro or Adlib cards, which do not need to load any drivers? And how about MIDI? can it detect and direct output to an attached MT-32 too?
Reply 9 of 15, by DosFreak
Nothing with DOSBox was modified to make it run in DOS, only the usage of HXRT makes it work.
SB16 and MIDI support are provided by HXRT.
Last year a modified build of HXRT was provided with Intel HDA and AC97 support.
Others benefits besides added game compatibility is the usage of scalers, screenshot, video recording, emulated sound and video cards. Also of course potentially 3rd party patches so pixel perfect, saved states etc.
Just discovered today that the mouse is unusable. Cursor stuck at top upper-left. Mouse buttons work fine though.
When I adjust the sensitivity with host ctmouse,dosbox settings or game settings I can get it slower but it's still unusable. Looks like this will require some coding skills that I lack.
It may be possible to use use djpp to make a DOS native DOSBox but that's beyond me and is possibly pointless since HXRT works. Would probably be great for learning though.
Just for kicks tried out MESA3D 7.5.1 and it works! Requires 32bit color and it's slow of course.
Reply 10 of 15, by gdjacobs
This is kind of amazing, but I still question how robust the support is. Plus, as Malik said, why not use a Linux build and avoid the limitations.
Reply 13 of 15, by Stiletto
retrogamerguy1997 wrote:
What is HXRT? I see it mentioned in this thread a couple times.
It lets you run a limited selection of Windows programs/utilities/games in DOS.
do the Fandango!" - Queen
Stiletto
Reply 14 of 15, by retrogamerguy1997
Malik wrote:
A quick Google search will lead to: ftp://retronn.de/dos/extender/hx/HXRT.TXT
sadly when I try to look things up, I never find what I'm looking for. Thanks though
that seems pretty neat
Reply 15 of 15, by Jo22
I don't know about you, but I would like to see a Win32s version of DOSBox somewhen.
Even if it would be just a proof-of-concept and with some restrictions,
to fit within the limits of Windows 3.1. 😁
