First post, by ookamithewolf1
ookamithewolf1
Offline
So, while going through the jumper settings on my motherboard in order to make sure everything was good, I discovered that it had a CPU voltage configuration, and has settings for 3.3 and 5v CPU. Now, I have a 5V 486-DX in it now, But I have a spare 3.3V AMD 100MHZ. Now, it list jumper settings for 100MHZ CPUs and the 3.3v, so is it possible I could run this powerful chip without frying it, or am I missing something here?
The Motherboard can be found here, and the voltage jumper setting are at the bottom of the page.
http://stason.org/TULARC/pc/motherboards/C/CO … 5-ALI-486G.html
