List of games that benefit from SMARTDRV?
First post, by smevans526
Title speaks for itself. I generally have a negative view towards SMARTDRV. Most early CD games I remember say 'turn it off'.
But it was defended in the 'Conventional Memory Trick' thread under the DOS section.
I actually can't find anything on specific games benefiting from SMARTDRV enabled. Did I overlook it? If not, can anybody provide some examples?
Reply 1 of 39, by derSammler
Games that consist of many files greatly benefit from SMARTDRV. Ultima 6/7 comes in my mind, that was way faster with SMARTDRV.
For CD games, it makes no sense naturally.
Reply 2 of 39, by dr_st
Generally, Smartdrive can make things better, but not worse (unless there is a bug). The only reason to turn it off would be due to the memory it consumes. However, there are plenty of ways to generate enough upper memory blocks to shove it there and leave enough conventional memory free.
Reply 3 of 39, by derSammler
That's not exactly right. It will make things worse if you enable it for removable or optical media, as that simply does not work well with what SMARTDRV does.
Reply 4 of 39, by Zup
Wasn't there a switch to disable cache on specific drives?
I'm selling some stuff!
Reply 5 of 39, by derSammler
Yes
Reply 6 of 39, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Yes, once I made sure to have enough low memory (umbpci or whatever that tool was called) I did use smartdrv with Ultima 7. it was noticeable. And Ultima 8 as well.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 39, by keropi
It's the /U switch that you are referring to - it does not load smartdrive's CD-ROM caching module - it really does cause issues in some games so it's a good idea to have this switch always enabled
Reply 8 of 39, by dr_st
Well, removable media was not really a thing back then. Optical - yes, and as was mentioned there is a special switch to control whether to load it or not.
What downsides can there be on enabling Smartdrive on CD-ROM drives? Are there games with known issues?
Reply 9 of 39, by derSammler
Loading times will be worse, as SMARTDRV does read-ahead, which isn't something you want on media with very slow seeking.
Reply 10 of 39, by Joey_sw
In my experiences, when installing the first Red Alert and its expansion it would finished much quicker, if I enabled the smartdrive for the CD-ROM drives beforehand.
-fffuuu
Reply 11 of 39, by clueless1
I've had a few issues with file corruption with smartdrv. I think if you're using a period correct hard drive, smartdrv can make a big difference. But even a hard drive from the late 90s is fast enough to negate many of the smartdrv benefits. If I do use it, I make sure to disable write caching, just to keep my files safe.
Reply 12 of 39, by Errius
Isn't there danger of data loss if a computer running SMARTDRV is shut down without first clearing cache?
"AI Requires Proof That You Are Human"
Reply 13 of 39, by clueless1
Yes. Only if you don't disable write caching though. In my instance, file corruption happened when I was playing a game in DOS with smartdrv write caching enabled, and the game crashed. Games sometimes crash, and if data is not written back to disk before that, bye bye data. 🤣
Reply 14 of 39, by smevans526
I have found that SMARTDRV slows WAKE OF THE RAVAGER and the SIERRA games the on run on WINDOWS 386 EXTENDED. Examples include TORIN'S PASSAGE and PHANTASMAGORIA. Their manuals specifically state to turn off SMARTDRV. This is on a system with 64mb of ram -- maybe even that's not enough memory. When I get the chance, I want to try LUCASARTS protected more games.
Reply 16 of 39, by Errius
Running wcd -s on a large DOSBox partition takes a long time the first time it's done after Windows startup. Subsequent calls of the same command complete very quickly however. That happens even without SMARTDRV in memory, and across different instances of DOSBox, so clearly Windows is doing the caching.
Reply 17 of 39, by Azarien
Floppies are removable media.
I always had smartdrv enabled, it really improved loading times on 486-era hardware.
Dominus wrote:
When it is on Windows you should indeed turn off smartdrv, I think.
Not need to. Windows 3.x and 9x is compatible with smartdrv.
Reply 18 of 39, by Jo22
SmartDrive can be counter-productive on slow systems.
Especially if you've got a fast HDD or a flash medium already.
I think SmartDrive makes sense for single-speed CD-ROM drives, though.
150KB/s are barely enough for CD-ROM games with FMVs.
Reply 19 of 39, by smevans526
Sounds like people on this forum use SMARTDRV about 5 different ways. I didn't use /u, inefficient. The Windows 3.11 system I have contains 64mb of ram, and probably uses only about 16mb at most. I think I'll set aside about 40mb and see how that influences operation. I have a large hard drive, so I configured games like KQVII to call data found in RESOURCESND and RESOURCESFX from the hard drive instead of the cd. They come as one big file, larger than 40mb.
Can SMARTDRV work with with files bigger than what's been allocated for the cache?
