First post, by tie pilot 3
Hello,
I'm attempting to run TIE Fighter, the Collector's CD version on a Win XP laptop...I'm sure you all understand my pain 😀
Here's what I've done so far...
I've downloaded DOSBox (v. 0.61)
I've downloaded VDMSound, and linked it up with the tie.exe command
I've gone into dosbox and mounted both the c:\tiecd directory and my d: as CD-Rom.
Here's where I run into trouble...whenever I try to run dosdrv, dosbox crashes. If I just run tie.exe, I'm brought to the install menu (yes, I've already done maximum install on the game).
As I'm sure you've guessed, I have no trouble running the game itself. However, getting the sound and my USB Joystick to work...ay, there's the rub.
I'm computer literate but I'm far from being a programmer...if anyone can give you some instructions in idiot-speak, I'd greatly appreciate it! 😀
