First post, by Almoststew1990
I am having some issues flashing my AMI BIOS. I have an MSI MS-6191 with an AMD 751 Irongate chipset. I am running BIOS 1.2 and I would like to update to 1.6, out of habit I suppose!
I download the BIOS file (A6191v16.exe) from MSI and it unpacks into the following files:
A6191v16.exe
A6191kms.160
A691ms16.txt
Amif826.exe
Flash.doc
The instructions don't seem to correlate to what was included in the BIOS package ("open the image in a new tab" to see the full text).
I don't have a COM file and I am not sure what it means by DRIVE:\>AMI_FLASH UTILITY_FILE BIOS_FILE etc etc
When I restart into DOS and run amif826.exe it presents me with this:
Autodetect doesn't detect my chipset, or the file to flash, and I am not sure where to go from here!
Any ideas?
Reply 1 of 8, by SW-SSG
I checked the package from the MSI site and it seems like "A6191kms.160" is the BIOS file to flash, based on what is said in "A691MS16.txt" and how it's a 256KB file. See if you can choose this as the file to flash from within "AMIFL826.EXE".
The .doc seems to have been distributed with different boards' BIOS updates, hence the different filenames used within.
Reply 2 of 8, by lazibayer
The flash utility detects your chipset and flash chip. All you need to do is to provide the filename and hit "Go Ahead". I don't see any issue here so far.
162.74 KiB
Reply 4 of 8, by Almoststew1990
Thanks for the help! So I would go to file, which gives me the option to specify a file to load and a file to save, on the C: drive.would I be loading or saving the new bios? It do I literally just press "go ahead" without setting anything?
Reply 5 of 8, by TOBOR
choose File first in order to specify the file to program. If the flasher program does not see the bios with the .160 extention then you will need to rename the bios file with the .rom extention before flashing.
If the truth hurts, tough shit.
Reply 7 of 8, by Almoststew1990
Thanks, changing the .160 to .ROM was the step I was missing. Got it flashed now.
I don't have a good reason really, I will be putting a faster CPU in soon and want to be sure the BIOS will recognise it!
Thanks for your help
