First post, by Jade Falcon
Rank BANNED
BANNED
Ever since I started my high end 775 build I had a old server case sitting taking up space.
I was thinking about selling it, but I know ill hate my self if I let it go.
So I thought some time after news years ill put together a socket 8 setup as a winter project.
But I have a few questions. (in before luckybob)
Frist what should one look for in a sk8 board?
What chipset sould I go for?
Is SD ram worth it?
What about nt4 vs 2k? For such a setup?
Any common bugs or problems with sk8 setups?
Would finding a pentium 2 overdrive be a worth wile?
Anything else i should note?
I plan to use the system for late dos and early 9x games. Anything late 9x and newer will be for my c2 setup.
I haven't chosen how many CPUs it will have, but im leaning towards one as dumb as it sounds.
Reply 1 of 6, by lazibayer
Aim for 1MB cache ones. They ain't much more expensive than their 256KB little siblings.
For chipset, you can choose:
440FX, most common, UP or DP setup, FPM or EDO
450KX, uncommon, UP or DP setup, FPM
450GX, uncommon, officially upto QP, but ALR 6x6 managed to put 6 sockets on the board. FPM
Some 440LX, 440BX board may support ppro via slocket and so you can get AGP and SDRAM.
P-II overdrives are quite rare and expensive. A couple of them sold for 100+ on ebay in August and one got sold for 300+ last week. They also have locked multiplier so there isn't much room in downclocking.
I am not sure what your goal is, but typically an sk8 setup has 1~2 cpus, 440FX chipset, EDO RAM and PCI video card. If you just wanted to run 2k/nt4/dos/9x games a sk7 or slot 1 platform is more flexible.
Reply 2 of 6, by kva
Well, dual Pentium Pro with 512MB RAM works great even with Windows XP. So 2k should work fine. Most of the time black ones (1MB cache L2) are not faster than 256kB versions, but they consume A LOT more power. Overdrives are great but as mentioned - expensive.
This topic (or article) can give you some answers - Pentium Pro 256K vs Pentium Pro 1MB vs Pentium II Overdrive
Celeron Tualatin vs Celeron Conroe at equal clocks
Pentium Pro 256k vs Pentium Pro 1M vs Pentium II Overdrive!
VIA C3 vs VIA C7
My website all about old hardware
Reply 3 of 6, by F2bnp
I'm not really all that knowledgeable on the Pentium Pro, however I'd like to point out that I don't believe there ever were SDRAM boards on socket 8.
Also, I'd recommend avoiding early chipsets such as the 450NX. I happen to own an Intel board based on this chipset and it performs slower than the 440FX and has issues with hard-drive detection and even Matrox cards! Windows 200 will probably be sluggish with a single Pro 200, but if you own an Overdrive (or two 😜) or find a dual CPU board, then I guess that'd be pretty awesome. I had a lot of fun trying out NT4.0 on my PPro 200 and seeing what software would run and what wouldn't 😁.
Reply 4 of 6, by Jade Falcon
Rank BANNED
BANNED
Thanks for the info.
And yes there are sk8 sd ram boards out there. I seen a few on ebay ether today.
Edit:
As for my goals, basically i watn a system that can run the older apps that my c2 system cant. Just late dos games like duke3d mw2 along with a few 9x games that are buggy in vista/7. Thats all. Oh and I want a system that would be right in my server case.
Edit:
I dont care one bit about downclocking, never once ran into a point were I needed it.
Reply 5 of 6, by lazibayer
Are you sure they are not DIMMs for EDO/FPMs?
Reply 6 of 6, by Jade Falcon
Rank BANNED
BANNED
No, but it sure looked like SD ram in the slots. Ill tray to find the boards.
Edit. Looks like a few of the ate 168 bin dims for edo ram.
But i sall one with 4gb of sd ram. Ill keep looking.
