First post, by cj_reha
- Oldbie
Recently got an AMD 5x86-P75 (X5-133ADZ) for socket 3 and planning to use it in my socket 3 build. Small problem, it is marked 3.45 volts and the board only has options for 3.3volts. Board is PC Chips M912 rev. 1.7 with white ISA slots. Is it safe to run it slightly undervolted? Or will it not work? Or strain the VRM?
Thanks.
