First post, by tabm0de
I got my hands on gateway 2000 486/33.
I found a card that I don’t know what it is for or what it is, also interested on what’s under the floppy drive
naa, nothing yet...
Reply 1 of 6, by clueless1
Can't see the connector on the back of the card, but the dimension from the top looks like 9-pin serial.
The drive under the 3 1/2" floppy looks like a tape drive.
Reply 2 of 6, by derSammler
Looks like an active ISDN card to me.
Reply 4 of 6, by jade_angel
That card definitely looks telecom-related. I'd agree with derSammler, probably, except that I don't often see DB-9 connectors for ISDN. OTOH, I haven't seen that much ISDN hardware. It could be a T1 or E1 interface too, possibly.
Main Box: Macbook Pro M2 Max
Alas, I'm down to emulation.
Reply 5 of 6, by derSammler
DB-9 connectors for ISDN were very common for high-end cards. All ISDN cards from Hermstedt for example (known for their Leonardo line of cards) used that connector.
Reply 6 of 6, by gdjacobs
Could be token ring as well, but those were usually prominently branded.
