CD Audio in games
First post, by Almoststew1990
Hopefully a very simple question: some games I play in my have an option (or solely rely on) "CD Audio". I assume this means songs are streamed from the CD?
The problem is when I do this I don't hear any music. Do I need one of these cables to get "CD Audio" in games because I don't have one at the moment!
http://www.ebay.co.uk/itm/Audio-Cable-CD-ROM- … 20AAOSwpDdVCr4T
Reply 1 of 3, by KT7AGuy
You are correct. You'll need one of those cables. WinXP made them obsolete, but if you're running Win9x you definitely need the cable.
Reply 2 of 3, by Stretch
If it is a Windows game, you can also duplicate the cd to a bin/cue file and load with daemon tools, because daemon tools can playback the audio stream. That way you wouldn't need that cable.
Since I see you have an SBLive, you can try either analog or digital cd audio cable depending on what your optical drive supports, if you don't want to use daemon tools or you're going to play games in MS-DOS.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Cubilux 7.1 USB
Reply 3 of 3, by the Goat
Almost correct. The game CD-ROM has multiple tracks. The first track has the file system data. Tracks 2+ are in normal CD Digital Audio format (often called red book audio). The game tells the CD-ROM drive which audio track to play and the CD-ROM outputs the sound as an analog signal -- like a normal audio CD player would.
That cable should work. Just be sure to adjust the correct input channel via the mixer software for your sound card. Alternatively most old CD-ROM drives have a 2.5mm audio jack on the front panel. You can also get the sound from there. But if the game also has digital sound effects those will still come out of the sound card and you'll have to mix the two audio streams yourself.
