First post, by nukeykt
Nuked OPN2
High accuracy Yamaha YM3438(OPN2) emulator.
The YM3438 is a CMOS variant of the YM2612 used in Sega MegaDrive(Genesis) and FM Towns.
Genesis Plus GX fork with this core integrated is available here: https://github.com/nukeykt/Genesis-Plus-GX
Features:
-Based on the YM3438 die shot reverse engineering and thus provides very high emulation accuracy.
-Cycle-accurate.
-Undocumented registers/features emulation.
-SSG-EG, CSM mode emulation.
-Compatible with the YM2612.
Samples
-Sonic the Hedgehog: https://youtu.be/ImmKy_-pJ8g
-Sega CD BIOS v1.10: https://youtu.be/s-8ASMbtojQ
Repository: https://github.com/nukeykt/Nuked-OPN2
Reply 3 of 7, by nukeykt
KainXVIII wrote:
Is there working retroarch core?
Here you go. You should set YM2612/YM3438 core to the "nuked opn2" in config.
genesis_plus_gx.zip
756.36 KiB
117 downloads
Reply 4 of 7, by KainXVIII
Thank you!
Reply 5 of 7, by James-F
Report on test build;
Something is wrong with the music (mame or nuked) only PCM channel playing when changing ANY setting in the options menu and returning to game.
When the game changes tunes/music the bug fixes itself...
Reply 6 of 7, by nukeykt
Fixed. Thanks!
Reply 7 of 7, by James-F
It still happens when changing the "YM2612/YM3438 core" option.
If indeed it needs a restart in emulation or tune, it should be changed to "YM2612/YM3438 core (restart)" in retroarch's fashion.
