First post, by olivil
Hi all.
Was simply wondering if it was possible to disconnect the CM-32P board from a CM-64 while keeping the CM-32L working? This could help with the noise and the "high" current requirements.
Has any of you tried it? I don't want to mess my CM-64 if it proves dangerous for the hardware...
Reply 1 of 1, by SuperDeadite
iirc, the audio output jacks are part of the 32P board. The 32P does all the mixing, the 32L sends its audio to the 32P via small wire harnesses. So if you were to disconnect the cables, the 32L would have no normal audio outputs. You could solder your own I suppose...
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
