First post, by weldum
Hi, I'm building a socket 7 machine. Sadly, I've sold every SuperSocket 7 board that I had, so I now have only 2 boards, both PCChips, one with an Ultron chipset, and the other (the chosen) has the Intel 430TX chipset, which has no AGP slot whatsoever. So I've wondering if it's possible to make an adapter for using AGP video cards on PCI slots. I have spare boards and video cards to make tests.
Here in Argentina seems to be rather difficult/expensive to get a PCI video card, especially if it has 3D support, like some low end fx 5200 or something similar. And most 2D have only 1MB, even the later ones, with the sockets unpopulated.
Thanks.
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 1 of 2, by cyclone3d
You would have to source the interposer chip and write the code yourself to make it work. It has been done with an AGP Voodoo5-5500 card.
https://www.youtube.com/watch?v=_8sYzOmoPoY
http://extreme.pcgameshardware.de/tagebuecher … ci-adapter.html
However, the much easier method is to get a PCI to PCIe x1 adapter so you can use a PCIe card in a PCI slot.
You will also probably want a PCIe riser cable with a power hookup to make sure the video card gets enough power.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 2, by Jade Falcon
Rank BANNED
BANNED
AGP to PCI adapters are out there. But they are very colstly and you would be better off woth a pci card or pcie to pci adapter.
