First post, by CornBrown
I've been programming some new cms upgrade chips lately with chips i dont usually use but I sold my last CT1350b recently so i have no way to test them in a live environment. If you have any experience with cms and a 1350b that will accept the chips, let me know and i'll send you a free upgrade chipset provided you can test it and give me details on it working pretty quickly.
PM me or reply on here and i can give you more info
Reply 1 of 2, by fitzpatr
Hi, CornBrown,
I do have a CT1350B, actually with the CMS upgrade (recent GAL) and tested correct. I should be able to swap in your set pretty easily if you don't mind shipping to Canada.
Either way, you'll need to make sure that whomever tests your chip has the CT1336, not the CT1336A.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 2 of 2, by CornBrown
Sounds good, PM sent
