First post, by ederra
Hello everybody,
I can not configure the SCSI controller (AIC-7895C) integrated in this motherboard MSI-MS6120, has two HD-MAE3091LP connected but in the manual does not appear any indication and I do not have the original installation CD.
I have no previous experience with SCSI controllers
I would appreciate any help
23.75 KiB
93.99 KiB
53.4 KiB
Reply 1 of 12, by derSammler
The SCSI firmware writes that no termination was found. The SCSI bus must have termination on both ends. So you need:
SCSI controller -> termination enable
First HD-MAE3091LP (middle of the cable) -> termination disable
Second HD-MAE3091LP (end of the cable) -> termination enable
Reply 3 of 12, by lazibayer
Can you find a 24pin connector CN2 on your drive? According to the manual shorting pins 23 and 24 will provide termination power.
Reply 4 of 12, by derSammler
Note that termination power is not termination. Termination is most likely done by installing two/three resistor networks or by using a separate terminator at the cable's end. Unless there's another jumper somewhere that clearly says "termination".
Reply 5 of 12, by ederra
derSammler wrote:
The SCSI firmware writes that no termination was found. The SCSI bus must have termination on both ends. So you need: […]
Modifying the BIOS the result is wrong
86.16 KiB
Reply 6 of 12, by ederra
Predator99 wrote:
You should also check the Adaptec-Setup (Ctrl-A). Usually this also works without terminator.
I have nothing clear to do in this menu 😵
Host adapter defaults
93.85 KiB
100.38 KiB
Reply 7 of 12, by ederra
Pins originally connected to both disks
Disk A
112.94 KiB
Disk B
65.37 KiB
The result is wrong
Reply 10 of 12, by ederra
lazibayer wrote:
Are both drives connected on the same cable or two separate cables? Both drives are set to ID0 so they cannot coexist on the same cable.
Are you using terminator(s)?
Both drives are connected on the same cable
All the pieces are in their original position, except the Bios (default)
I have no terminator, the HDs are connected as they were originally
Reply 11 of 12, by ederra
Termination is still off in that screenshot.
I second the question: how exactly is everything connected? Can you make a photo?
108.58 KiB
135.72 KiB
88.27 KiB
72.83 KiB
Reply 12 of 12, by jade_angel
Looks like you have the drives connected to channel 1, which has termination disabled in the BIOS. Turn on termination there and see if you have better luck.
Also, remove the TERM PWR jumper from the drive in the middle of the chain and change one of the two drives to a different SCSI ID. (They cannot both be on the same ID. That's like having two IDE drives both jumpered to master, but worse. It shouldn't matter what ID you change to. Use the extra jumper you yoinked from the TERM PWR pins to do so.) You shouldn't need the START CMD or SINGLE/WIDE jumpers set either. They're the same model, they're both LVD/SE on what is, IIRC, an LVD bus, so you shouldn't need those.
Main Box: Macbook Pro M2 Max
Alas, I'm down to emulation.
