First post, by olivil
I have a PC equiped with an AWE64 and an Ultrasound MAX. I use the AWE64 as my MIDI source for my external modules. These modules are plugged in the line-in of my GUS, and my GUS is plugged in the line-in of my AWE64.
I like to have sound effects on the GUS, and MIDI through my AWE64. Usually this lets me dodge the stutter over 11KHz sampling rate that I get in Duke3D when I have both MIDI and sound coming through the AWE64.
However my GUS has the tendency to mute its line-in when I use it as a sound source... So I can't hear music from my modules. This is the case with Duke3D.
I know the solution is a 4 channel mixer, but that's out of scope for me right now. 😀
Is there a fix somewhere or is this a limitation of the GUS?
