First post, by Qjimbo
I have a Voodoo 5500 AGP (3.3v). It's a classic card, it looks great with Glide, and I have fond memories of using it, with it now sitting in a box. I'd love to put it into use again, but the problem is for many early 2000s titles, it's simply too slow. It benefits just a small slice of games. I can't get my retro gaming fix out of this card alone, and I would prefer to use the real hardware instead of nGlide.
Since I want to built one retro gaming computer for all my needs, the question is how can I have the AGP Voodoo 5 available and a newer graphics card available in one machine? I've thought of a couple of options:
1) AGP Switch/Selector
Some way of toggling between the AGP card being used at power-off. There's nothing like this that exists to buy.
a) There are no BIOS/Software settings to tweak. Just power off, switch the card toggle, then startup again, with a VGA Y cable to both cards in the system.
b) No modding required as you can find powerful motherboards with universal AGP slots.
c) AGP guarantees Windows 98 compatibility.
2) PCIe+AGP Motherboard
There are some motherboards with an AGP slot and PCIe slot, the most popular being the ASRock 939Dual-SATA2. So this sounds good, get a PCIe card for modern games, and put the Voodoo 5 in the AGP slot. Couple of problems:
a) Voodoo 5 is 3.3v AGP and that motherboard is 1.5v AGP-only, so it won't work. The Voodoo or motherboard would have to be modded (risky)
b) The PCIe slot is dubiously compatible with older OSs like Windows 98. While other threads seem to suggest they work, it's not as reliable as AGP.
(An older graphics card is also more of a "waste" of a PCIe slot, the temptation would be there to put in something too new for Windows 98 to support, where as right now I have a readily available AGP Geforce 6800GT, though this isn't such a big deal.)
3) Dual AGP motherboard
Apparently, these don't exist anywhere, so not an option sadly.
Either way it's clear there isn't an "off-the-shelf" solution to this issue. Even if I had the PCI Voodoo 5, this would completely take all the PCI bandwidth, which could cause problems with a PCI soundcard or USB card for example. I guess I'd just like to open the floor to ideas, suggestions, maybe if anyone has dealt with a similar problem.
Follow me on twitter
Reply 1 of 12, by fitzpatr
The reality is that any solution other than "Build a second tower" or "Buy a PCI Voodoo5 or alternate graphics card" is needlessly complex.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 2 of 12, by slivercr
The V5 and a "powerful" PCI card are a 4th option.
Use the V5 in win98 with the PCI adapter disabled, and the PCI card in another OS with the V5 disabled.
May work.
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
Reply 3 of 12, by Qjimbo
True - I've known that from the beginning though, thats the status quo right now. But as more and more people become interested in older graphics hardware and retro pc building, I expect this sort of thing will come up more and more. So maybe there is a different way?
May work.
That's a smart idea having two OS installations, each one with an alternate graphics card disabled. Not sure about getting a PCI graphics card though, doesn't solve the bandwidth issue, and as far as I know most PCI graphics cards aren't really that fast.
Reply 4 of 12, by lazibayer
May work.
How fast do you need? AFAIK the fastest PCI card that supports win98 is GF6200, and GT430 is among the fastest PCI cards regardless of OS support.
Reply 5 of 12, by Qjimbo
I had no idea there was a plain PCI graphics card that new! That definitely changes things, might be a good solution to get the best of both, even if it doesn't work in Win98, I can use XP as the secondary OS. I can't find the plain PCI version for sale anywhere though, though I found someone talking about it with ubuntu so it must exist.
Reply 6 of 12, by CkRtech
OK. So just for funsies.
You could take an AGP extension cable to extend the slot up to a riser card.
47.3 KiB
At this point, you could create a PCB with two AGP slots. You could google around for riser cards to get an idea for components you might need. You may also look to riser cards for parts, although perhaps you can purchase an AGP slot from an electronics place. I've never looked.
89.42 KiB
You are tasked with at least (and I am making broad generalizations and assumptions) -
1: Creating a PCB to support two slots of the appropriate slot type depending on your motherboard
2: Putting some caps on your voltage lines - and AGP has a lot of voltage lines & provide enough power (appropriate voltage) despite the "extras" after the AGP slot.
3: Rigging up a switch circuit to only power the appropriate card
4: Keeping your bus from getting too much noise
5: Use/Mod a case that could use two cards. Possibly use a board that normally has a riser card anyway and design your own riser/PCB as mentioned in #1
6: Dual boot OSes
So... pretty simple. 😁
Displaced Gamers (YouTube) - DOS Gaming Aspect Ratio - 320x200 || The History of 240p || Dithering on the Sega Genesis with Composite Video
Reply 7 of 12, by cyclone3d
You will be looking for a while for a GT430 in PCI. The generally only pop up once a month or so on eBay. And when/if you find one it will probably not be very cheap.
The easier option is to use a PCI to PCIe x1 adapter and a PCIe riser cable with a power plug. You'll just have to mount the adapted card somewhere else.
Adapter:
http://www.ebay.com/itm/Startech-com-Pci-To-P … 1-/253153189362
Riser cable:
http://www.ebay.com/itm/PCI-E-Extention-Cable … ex/322495476871
That way, you can use pretty much any newer card you want to. The bandwidth available for the card will suck, but it will still be fast enough for what you need it for.
Edit:
The PCI to PCIe adapter cards use the same exact chip to do the conversion as the "high end" PCI cards do.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 8 of 12, by x0zm_
CkRtech wrote:
:neutral: ... :dead: ... :lol: […]
6: Dual boot OSes
A friend and I actually designed one of these a few years back. We never got around to getting the PCBs made but we had the exact same idea (using jumpers though).
Wish I still had those EAGLE files...
Reply 9 of 12, by CkRtech
Aww man! That would sure save some time...
Reply 10 of 12, by Qjimbo
Oh yes, so simple! haha! 😎
I did see those ribbon cables and something along those lines crossed my mind, but obviously a custom PCB is quite far outside my expertise.
Interesting. Jumpers would work, since that would be trivial to wire up to a pole switch on the case.
cyclone3d wrote:
You will be looking for a while for a GT430 in PCI. The generally only pop up once a month or so on eBay. And when/if you find o […]
Adapter:
Riser cable:
Edit:
Very interesting, thanks! I've see the adapters that do the reverse, it never even occurred to me there would be something to do PCI motherboard->PCI-E card.
Reply 11 of 12, by cyclone3d
A really interesting fact is that the chip is a two way converter. The same chip is used for both adapters.
Makes no sense why the PCI card in a PCIe slot adapter is way cheaper than the other way around.
YMF7x4 Guide
Reply 12 of 12, by Qjimbo
That is interesting! And yeah, I guess the pricing is all supply and demand rather than actual production cost.
It appears that the adapter does work decently well with PCIe graphics cards, based on the reviews on newegg.
The adapter runs at 133MB/sec, so a slower 1x PCIe mode (250MB/sec), which concerned me at first, but then I found this page where someone did some speed tests comparing PCIe x1 with x16, apparently the difference is surprisingly little, if the card has plenty of VRAM.
http://arstech.com/install/cms-display/ste_spdtst1.html
So I thought - everything looks great, but then I found this thread: Jaton 9500GT PCI BENCHMARKS/REVIEW
i486_inside seems to think that running a fast graphics card on the PCI bus causes a lot of lag and slowdown, as on many boards it is crowded with other things, such as hard drive I/O, so this is concerning to me. If the PCI bus was completely standalone, then we might have a solution, but I don't know if there are any motherboards with a fast separated PCI bus and a universal AGP slot.
EDIT: Closest thing I could find to a "priority" PCI slot was this Orange Communications PCI slot on the MSI K8N Neo2
Not AGP though so doesn't solve the issue, but might be something for Voodoo 5 PCI users, not sure if it works any better than regular PCI.
