thrust master f-16 flcs
First post, by cnpr
Hello all, I bought a thrust master f-16 flcs joystick on ebay. I'm currently having issues with the buttons not working correctly. It currently pluged into a creative model ct4740 (I believe its a creative pci 128.) and the keyboard at port to a asus p55t2p4. I am new to joysticks in general. I can get the joystick itself to move just fine. my first main question is that are there any drivers for windows 9x in if so where can I find them? second will a gameport card help this issue?
Reply 1 of 4, by cyclone3d
I am guessing that only a few buttons are working, correct? Maybe 2 or 4 out of all of them?
Take a look here:
http://www.warrenernst.com/thrustmaster
Programming software is available there as well as some other info.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 4, by skitters
It probably just needs programming. If it was used with a TQS or WCS throttle
before you bought it, it may be programmed to work with the throttle instead of
by itself.
creative pci 128.)
According to http://support.creative.com/kb/ShowArticle.aspx?sid=5790
the ct4740 is a Sound Blaster 16 PCI. I don't know if that makes any difference
to the joystick. I thought it was only ISA sound cards that were a problem.
Did your FLCS come with any documentation? Mine came with a card that mentions
installing "Thrustware" from the disk. The F-16 FLCS floppy that came with my
joystick was mangled (metal part torn halfway off) and unusable. However I
found a download at the web archive (flcs-ccc.exe) that seems to be the
contents of the floppy.
http://web.archive.org/web/20030303062156/htt … ks/exe/F16FLCS/
The label of the floppy says:
Thrustware F-16 FLCS
Command & Control Center
Installation Disk
Place in drive A or B
Type Install, follow directions.
The flcsrt200.exe file is mentioned under Support for the F16 FLCS at this
archived site
http://web.archive.org/web/19991006174716/htt … ystick/flcs.htm
and described as being for "If you
have a Pentium Pro or Pentium II and are experiencing runtime error problems,
Download the latest loader for the FLCS (which is the flcsrt200.exe file)
If your computer is older than a Pentium Pro, you don't need it.
There is also something called "Fox Two" from the Flyfoxy website that I've
seen recommended, and which is supposed to run in Windows.
http://web.archive.org/web/20040204110205/htt … :80/FoxTwo.html
Here are scans of the card that came with my FLCS.
Reply 3 of 4, by cnpr
I've tried to find the fox two program but to no avail. doe anyone know where I can find it at?
Reply 4 of 4, by skitters
I put the wrong archive link for Fox Two in my post.
I think my links are all fixed now, but try
I think it's still downloadable from there.
Click "Fox Two Freeware" in the frame on the left to get the description
I think the direct link is http://web.archive.org/web/20040313035007/htt … m/FoxTwo2_3.exe
Seems to download a 3.2 mb file for me.
