First post, by lowlytech
I have what looks like a later model 4/33 board and have a bigger sized hard drive (4.3GB) I would like to install in it. I had a similar issue with an IBM PC340 where I ended up pulling the hard drive out and fdisking and formatting it in a newer system and that it did work in that case with all paritions. However following that solution for this compaq partly works. Doing this, I can see the primary partition @ 2GB, but the extended partition is totally inaccessible or not seen. This BIOS/CMOS will let me set the cylinders up to 9999, 16 heads, 63 sectors which comes out to approx 5GB.
Does anyone have any firsthand experience with this type of machine where I might get a BIOS update or some other trick from keeping to have to use a drive overlay program? My OS will be MSDOS 6.22
