First post, by Cga.8086
Im starting to think that my old motherboard pcchips M919 is dead.
I have installed a gotek floppy drive emulator, and flashed a bunch of bootdisks from the well known website
from win95 to win98 and winME, i even loaded MS DOS 6.22 disks on the gotek and no go. (the gotek works because i used it on another pc)
nothing works, after boot sometimes i get
"STARTING MS-DOS..." and nothing happens
sometimes i try other boot disks and i dont even get the starting ms-dos and hangs.
I also tried loading DOS 6.22 on the gotek , with spanish to see if it loaded and also hangs on starting ms-dos
then i installed a CF to IDE adapter, with a 256mb cf card that i did a sys c: on a core2duo machine, and used it on the 486 and also hangs on starting-msdos
i have no clue of whats going on, the motherboard is busted?
is "starting MS-DOS" a common problem?
(i used different ide cables and no go)
Reply 1 of 9, by lazibayer
Have you tried booting with a real floppy or IDE drive?
Reply 2 of 9, by Ampera
In line with what lazibayer is saying, it sounds like an issue reading something. Normally busted boards will be weird in other places, this is not something I have seen much before.
Try a real diskette drive and report back.
Reply 3 of 9, by Cga.8086
guess what, dead coast module.
that is what was preventing the pc from booting and hanging on starting ms-dos
are the chips in the coast module replaceable? i have soldering skills, but im not sure if the memory can be found online
it is such a stupid little thing with 9 chips. I hope i can find replacement chips and fix it
Reply 4 of 9, by Cga.8086
forget i asked
a bunch selling AS7C256-15JC on ebay
really pissed off, wasted like 2 hours changing cables and doing boot disks.
and the coast looked fine because when you boot the pc it says cache enabled and staring ms-dos
Reply 5 of 9, by Rawit
Does it work without the Gotek?
YouTube
Reply 6 of 9, by Cga.8086
yea i was able to boot dos 6 and format a Hard drive
the isue is the coast module. the chips or maybe one if those smd resistors but i dont know how to detect if those tiny resistors are good or bad
Reply 7 of 9, by Ampera
Depends on how the memory in the COAST module is soldered. In theory you can hand solder right around everything except most BGA (which didn't become a real thing until much later than COAST). Finding the chips would be another thing, and I'm not sure how good your surface mount solder skills, because I would wager that's how the memory is attached to the module. Probably a better idea to just get a new COAST module.
Reply 8 of 9, by Cga.8086
actually it is easy. you just need to cut the legs carefully and remove each memory
then buy solderig paste a ceringe and a tiny drop on each contact. then hot air
soldering paste is way better than regular solder for small components
the memory is on ebay. but im not sure id the memory is the issue or the other tiny little components
Reply 9 of 9, by Ampera
I guess you could do that. Just saying it's normally not easy for most of the average Joes around here.
