First post, by GabrielKnight123
I have an AWE64 Value CT4520 and I need help to set the jumpers for Line-out/speaker to Line-out, I found a page here:
http://pbclub.pwcsite.com/PBInfo/Jumpers/Soun … WE64-VA-12.html
that says "CN7" is the one I need to set but it does not mention which pins need to be open or closed.
Reply 1 of 5, by derSammler
CN7 should have two jumpers set, one for each channel. Just move both jumpers by one pin.
Reply 2 of 5, by GabrielKnight123
Should I place the jumper horizontally or vertically
[A] [0] Horizontally - A+B closed and L+R closed
[L] [R] [0] 0 not used
or
[A] [L] [0] Vertically A+B closed and L+R closed
[R] [0] 0 not used
Reply 3 of 5, by firage
It's not a jumper block, but an internal header.
1 Left channel line level audio out
2 Right channel line level audio out
3 Pin is cut to provide keyed connection
4 Analog Ground
5 Left channel speaker audio out
6 Right channel speaker audio out
My big-red-switch 486
Reply 4 of 5, by GabrielKnight123
Sorry I dont understand Firage from what you said can you tell me how to put the jumpers for line-out?
Reply 5 of 5, by firage
The pins aren't for jumpers. It's a connector.
You have both jacks for line level out and amplified speaker out at the back in any case.
