First post, by BeginnerGuy
I'm curious AWE32 owners, if there is any variation in the length between different models of the awe32 WITH simm memory expansions? According to wikipedia, the awe32 is 356mm (14.xx inches). My newly acquired case measures just over 13.5" (~345mm) from the start of an isa PCB to the front of the case (I could gain over another inch if I cut out the metal housing, which I believe is for a fan, but don't really want to.
Are the later AWE32s like the 3990 any shorter? Or are they all 356mm. I'm curious if any of you have them on hand to measure, I only have a CT3600 SB32.
If they are all that big, I'll just have to pair a SB16 with a CT3600 or save my chips for a 64 value + simmconn. Not too huge of a hassle.
Sup. I like computers. Are you a computer?
Reply 1 of 4, by skitters
My ct3990 card is about 13 inches long.
I think a ct3990 will be too long for that 13.5" case.
Reply 2 of 4, by BeginnerGuy
Well 13" would fit in a 13.5 inch space 😜, that's why I'm asking for somebody to pull out a tape measure (if it's not a big hassle).
The case is 15.5" long. I'm measuring from the start of an ISA PCB to the end of the intake fan housing to get 13.5.. so anything under 13.5 would fit unmodified, if the 3990 is actually 13" then I'd buy one.
Reply 3 of 4, by skitters
I did measure it, the green plastic part, not including the metal bit on the end.
If your case is 15.5" long you might get it in there.
I had trouble with a 17" long case, but that was partly because of the placement of the hard drive cage.
