First post, by Thraka
Does this card handle 16-bit sound? No matter what I try (duke3d/rott) I cannot get 16-bit sound configured properly. Nor can I find any settings for it in the driver executable. Does this card only do 8-bit sound in dos?
Reply 1 of 3, by Kamerat
No, as for most Sound Blaster compatible cards you're "limited" to Sound Blaster Pro comaptibility. It does handle 16 bit audio only in it's native mode.
Avance Logic ALS120 and CMI 8330 are two chips that can emulate SB16 on the ISA bus.
YouTube channel
Reply 2 of 3, by gdjacobs
It can emulate 16 bit WSS, I believe. Some titles support that mode.
Reply 3 of 3, by Thraka
Thanks for replies!
