First post, by sunyata_zero
sunyata_zero
Offline
Hi all, i use Ubuntu 16.04 with dosbox 0.74 and get no audio, when i launch dosbox i get these messages:
sunyata@sunyata-Aspire-ES1-131:~$ dosboxDOSBox version 0.74Copyright 2002-2010 DOSBox Team, published under GNU GPL.---CONFIG:Loading primary settings from config file /home/sunyata/.dosbox/dosbox-0.74.confMIXER:Got different values from SDL: freq 44100, blocksize 512ALSA:Can't subscribe to MIDI port (65:0) nor (17:0)MIDI:Opened device:none
What i've tried so far: After reading a tip on askubuntu i updated the .conf file with "core: normal" (rather than "core: auto"), this doesn't change anything for me
Please help me solve this problem!
Kind Regards, Tord
Related question on askubuntu: https://askubuntu.com/questions/596599/how-do … -dosbox-install
My system
OS: Ubuntu 16.04 64 bit
Dosbox version: 0.74
sunyata@sunyata-Aspire-ES1-131:~$ sudo aplay -l**** List of PLAYBACK Hardware Devices ****card 0: PCH [HDA Intel PCH], device 0: ALC255 Analog [ALC255 Analog]Subdevices: 1/1Subdevice #0: subdevice #0card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]Subdevices: 1/1Subdevice #0: subdevice #0sunyata@sunyata-Aspire-ES1-131:~$
