First post, by cliffclaven
- Newbie
My Turbo LED display has only a ribbon cable for connecting to the "deck" (I don't know what you call it). I must assume that power to the display comes from the deck, so I have to feed it power - 5 volt I understand from searching other threads. I do have a molex 4 to 2 pin (black/red). Any ideas which pins on the deck would be for receiving power?
Edit:
Now I found this adapter, so this is more likely the power for the unit (original post edited)
