First post, by rolloLG
Descrizione
Percorso dell'applicazione che ha generato l'errore: E:\SteamLibrary\steamapps\common\Enclave\Enclave.exe
Firma del problema
Nome evento problema: APPCRASH
Nome applicazione: enclave.exe
Versione applicazione: 1.0.0.1
Timestamp applicazione: 3e1f2256
Nome modulo con errori: DXGI.DLL
Versione modulo con errori: 10.0.16299.15
Timestamp modulo con errori: 6992878e
Codice eccezione: c0000005
Offset eccezione: 00059fab
Versione SO: 10.0.16299.2.0.0.768.101
ID impostazioni locali: 1040
Informazioni aggiuntive 1: 2beb
Ulteriori informazioni 2: 2beba6fb4680d73a8c78ca7c24ccdb46
Ulteriori informazioni 3: 3ad0
Ulteriori informazioni 4: 3ad0e9f4486e91d86927e4a71227ee49
quitting Enclave with ESC key at credits screen (when quitting).
Reproducible (1/10) with 2_54 and WIP38.
Windows 10 x64 FCU 1709 (16299.19), Nvidia 388.0 WHQL
ROG-mini-22x13.png SCAR 18 G834JY: i9-13980HX, 32GB DDR5@5600, 4090 laptop 256 bit 16GB, 2560x1600 16:10 G-Sync, NVMe 6GB/s, 8BitDo Arcade Stick, EasySMX X10 controller, ROG Strix Carry Mouse.
Reply 1 of 6, by rolloLG
There is no crash, without dgVoodoo2
Reply 2 of 6, by Dege
Are you on Fall Creators Update?
I can try Enclave with FCU later, but sadly I must say that, as it turned out, dgVoodoo is currently incompatible with that.
Enclave works perfectly on Creators Update though.
Reply 3 of 6, by rolloLG
Yep, I'm on FCU now... and have had the same impression that problem started only after FCU.
The crash on quit is random but still happens with a certain frequency.
Steam Guide using your dgVoodoo2 wrapper: http://steamcommunity.com/sharedfiles/filedet … s/?id=418308035
Reply 4 of 6, by Dege
I tried Enclave on my Win10 FCU, but unlike some other games, this one worked perfecty for me, there is no crash at exit.
Reply 5 of 6, by rolloLG
You have to play a bit (first level, prison...). Then exit and press ESC when quitting at the exit credits with the skull and scrolling credits (just to speed up exiting).
It happens randomly, let's say 1/5 times. Worked fine 'till FCU.
I use dgVoodoo2 WIP38 also for The Settlers IV GOLD (GOG) and works flawlessly there.
N.B.: you may not see Windows crash requesters warning of the issue, but you'll find all crashes logged in the Reliability Monitor.
Reply 6 of 6, by rolloLG
News: I updated to Windows 10 x64 FCU 16299.98, Nvidia driver 388.43 WHQL, GeForce Experience 3.11.0.73.
Seems can't reproduce the crash on quit anymore 😀
I'll post here again if I can reproduce the bug in the future...
