AT PC standoffs question
First post, by harddrivespin
Forgive my stupidity, but how exactly do you use AT Plastic standoffs with an AT mobo?
Reply 1 of 1, by CkRtech
You have three possibilities
1: You have a hole in your case for a metal screw stand-off like in a modern ATX case. Sometimes there will be a couple of places for these in an AT case (and the other mounting points require plastic standoffs).
There are two plastic/nylon stand-off types
2: You have a larger hole in your case that can accommodate a plastic standoff with a peg on bottom like this one:
The attachment 15standoff.Main.jpg is no longer available
It can then be slotted into the motherboard like so:
The attachment 04fig09.gif is no longer available
3: You have a spacer. Same as #2 above, but there is no peg. It just creates a little foot for the mobo to rest against the mounting plate in your case.
The attachment standoff3.Main.jpg is no longer available
It is perfectly normal to use some combination of those three in an AT case.
