5V 66MHz PCI?
First post, by Bobolaf
Does anyone know of any motherboards with a 5V PCI slot that run at 66MHz? I don't mind if it is 32bit or 64bit PCI slot, the important part is that it is 5V and can run at 66mhz. Almost every motherboard I look at it is only 3.3V PCI slots that can run faster than 33MHz. đŸ˜”
Reply 1 of 5, by BitWrangler
I think you need to look at server/workstation boards for that.
Reply 3 of 5, by Bobolaf
Thanks BitWrangler your right it does look to be only server boards. I have spent half the day looking and only came up with the ASUS CUR DLS (U160 SCSI model) Nice board but boards with the U160 SCSI option are rare as hen's teeth.
Kamerat that is brilliant thank you! That board look to be relatively common as well so I have to grab one. I wonder if there are any standard ATX or intel boards that boast 5V 66MHz PCI slots?
Reply 5 of 5, by Gamecollector
Ozzuneoj wrote:
Just curious, what are you planning to use in the 5V 66Mhz PCI slot?
Theoretically any universal PCI boards with the 66 MHz support will work. Because the 66 MHz detection not checks the signal environment voltage.
