First post, by Smack2k
If you were going to put one of these into a 1100 MHZ Athlon PC, which would you choose?
The GTS is newer, but the Quadro has more memory (but is older and an "upgrade" to the GeForce256)
Reply 1 of 2, by Koltoroc
GTS. The Geforce 2 is much faster than any Geforce 256 based card and neither the quadro nor the CPU are fast enough to run games (I assume it is about games) at resolutions high enough or games that are new enough to actually benefit from 64 MB
Reply 2 of 2, by Smack2k
Cool...thanks for the info...
