OK guys i took the time to take a lot of pictures for your pleasure
the pc was in awfull shape, dust everywhere, spiderwebs everywhere, case was not cleaned in like 30 years or so, i cleaned it a lot from the outside and now you can see this piece of history ..prehistoric dinosaur.
SOme things i want to mention, altho the sticker on the right bottom side says type 8530-021 and when i google that number people had a 286, but this machine i dont think its a 286 because inside it has a siemens SAB 8086 2-P chip, there is a photo but i dont think you can see the markings, that chip is on the back of the floppy drive. So this must be 8086
Other things i saw were, the dam thing works, from the era where everything was rock solid, this thing booted at first try, the hard disk does sound like a terror movie.
Notice the card in the slot, that card with gold pins was not inserted correctly into the slot, and the machine booted fine i got DOS shell. When i inserted the expansion card into the slot, the machine did not want to boot and gave some kind of error asking me to retry or not.
the guy that i bought it from told me ,,,hey it even has this wood on the floppy drive, looks like it came with that from factory? so it doesnt get dusty or what?
THE BATTERY IS MASSIVE, i dont see any leak, should i remove it?
i was unable to play with it just a little bit, i dont even know how to enter the bios, it just boots and calculates like 600k
