First post, by appiah4
 - l33t++
I installed an S3 Trio64V2/DX (Model No SST-2065/75, no information on brand on the PCB) in my P133 PC for DOS compatibility but my god does it have holy pants Batman gray blacks..
I know this is a documented issue, but I can't seem to figure out the best way to fix this. Is there a BIOS out there that I can safely flash onto the card to fix it? Can the flash be done via DOS and not a BIOS flasher device? For reference, the card I have is below:
I also happen to have this regular S3 Trio64 by Surf media, but I refrained from using it because it's an older model and 1MB only. Maybe I should just use this? I can just pull the extra RAM from one card and move it to the other, now that I have the tools for that.
