Tie Fighter
First post, by Mindy
It works perfectly including music, sound , and joystick initially.
But after playing about 3 minutes, the screen freezes but the sound is still playing.And when I shot, it could play,too.
does anyone have the same problem?or who knows the solution?
Reply 1 of 2, by Guest
What system are you running?!?! Processor, RAM, OS, and such?!? I once hada problem with something called a Stack Overflow, which is where you are running an older game on a new machine and you don't have enough conventional memory.
To check, get into a command window ( start, run, command ) and then type in c:/ mem /all I believe. Check the memory there compared to your memory ( RAM ).
Also, check the Lucas Arts Forumns. They might have a solution as well.
