First post, by wallstreetobserver
Hi,
I have 2 programs that won't run in DOSBox because the date command is not supported and there is no printer support. Is there a version that supports one or both? If not, is there another DOS emulator that does? Thanks
Reply 1 of 2, by emendelson
DOSBox supports the DATE command; you can display the date or change the date.
For printing, try vDos (which has printer support, but does not support using DATE to change the date):
http://www.vdos.info
Reply 2 of 2, by emendelson
Or you can use vDosPlus which supports DATE and printing. (To change the date at the command prompt, the vDosPlus config.txt file must have SYNCTIME = OFF). My build of this (approved of by both Jos Schaars, author of vDos, and Wengier Wu, who made the changes for vDosPlus) is here:
http://www.columbia.edu/~em36/vDosPlusDec2017.zip
