First post, by Ozzuneoj
- l33t
After recently experiencing my first tantalum explosion, I'm feeling a bit less adventurous when it comes to using 25+ year old cards and motherboards with tantalum caps. Especially ones that already have failed tantalums.
I don't really like the idea of using "new" tantalums as replacements, as its hard to know how old they are if you find some, and they could potentially be only a few years away from exploding already depending on how long they've sat in storage. Plus, they aren't cheap.
I used an electrolytic I had laying around to fix a New old stock EGA card I bought last year and it worked fine, but it was only one cap. If I'm redoing a whole board, I want to be sure the replacements are functionally similar enough to keep the device operating as designed.
Longevity is also a concern. I have read that modern multi layer ceramic caps (MLCC) can be suitable replacements for tantalums in some situations these days, but I'm not that savvy with the electrical aspects of these things to know why this would or wouldn't work on, for example, an old video card or motherboard. I like the idea of using ceramics, because they are so easy to work with, durable and reliable.
Just as an example, I'm looking to replace dozens of 10uf 16v tantalums on several different boards. I'm looking at these for possible replacements:
https://www.mouser.com/ProductDetail/TD ... Qvfayqc%3d
Would those work? What would be a suitable electrolytic alternative?
