Volume Knob Repair
First post, by Tempest
Last night while playing with my MT-32 I noticed the volume knob seemed sticky so I took it off and sprayed some contact cleaner on the stem, but when I wen t to push it back in the stem pushed INTO the system! Opening up the MT-32 I noticed that the little volume board had come dislodged from the front of the case. It appears to be held in place by four little arms, which I tried to bend back into place. The board is now back to where it should be, but it doesn't seem 100% solid and when I turn the knob the volume generally goes from 3 to 98 instantly, but I can get it back down to 50-60 if I play with it a little (it likes to slowly creep up though). While I can live with this, is there any good way to fix it?
--- AtariProtos.com ---
For when excellence and burnished fineries need to gently visit the warmth of your tablery
