First post, by squiggly
I have hundreds (at least over 100) of old cards of all variety sitting in antistatic bags, just folded across. I want to tape them closed but I know ordinary sticky tape is a high level static electricity generator. There is such a thing as antistatic tape (often what is used to factory seal), it usually has a kind of pattern printed on it. But I can't seem to find it anywhere to buy locally...and what is on eBay is ridunkulously expensive.
Something like this https://www.3m.com/3M/en_US/company-us/all-3m … 93719466&rt=rud
Reply 1 of 13, by luckybob
its fine.
The bags job is to SHORT OUT all the contacts of electronics. static damages things when it goes THROUGH parts. You can wrap things in aluminum foil and it will protect the same.
Reply 3 of 13, by gdjacobs
luckybob wrote:
its fine.
Nope. The job of static bags is to provide a certain amount of resistive bleed, thereby dissipating any static charge. They won't necessarily crowbar the contacts on your retro stuff.
Reply 4 of 13, by luckybob
Well, maybe not a complete dead short, but the principle is the same.
The pink bags are trash!
https://www.youtube.com/watch?v=imdtXcnywb8
Reply 6 of 13, by Jo22
Old, but also interesting :
https://www.youtube.com/watch?v=hLOQ7zOWGAA
First Epsiode (1 of 4):
https://www.youtube.com/watch?v=4WHbcd4NGJQ
In practice, however, I'm afraid no one really cares anymore. 🙁
Modern CMOS parts have built-in ESD protection (to some degree; they sure can still be damaged),
while ancient TTL chips are usually too primitive to take damage due to their low density (microns instead of nanometre).
I'm not saying that they can't be damaged by ESD, Of course. Sure they can (esp. RAM chips)!
Though personally, I believe that early CMOS parts might be more sensitive to ESD.
At least, I wasn't able to kill any TTL chips so far (I often was walking over carpets, when I was working with them).
Anyway, I'm a layman when it comes to these things (that topic is rather scientific),
so perhaps it is better to be on the safe side and try use proper antistatic bags.
For my old mainboards, I'm using antistatic mats, even. 😀
Reply 7 of 13, by torindkflt
The few times I've seen a previously-opened antistatic bag taped shut, it was taped with plain paper masking tape and in all of those cases it never seemed to cause any issues.
Reply 9 of 13, by keropi
Using antistatic tape is just too much IMHO unless the component in question is bigger than the bag... you can just use paper tape and be done with it if you are worried about static build up.
The pink bag on the EEVBlog video is not an antistatic one, it's just a packing bag. There are proper pink and transparent antistatic bags with esd markings and all the bells and whistles.
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 11 of 13, by derSammler
Just do a google search. There are lots of (technical) articles explaining why ESD is a big problem, even if many people think it isn't, since "they never had any ESD damaged". Problem is, most articles are long and not easy to understand. Those two blog entries are, no matter the source.
Reply 12 of 13, by Predator99
I have everything in pink bags otherwise I would pay more for the bag as for most cards...
It offers basic protection against ESD but main point is that they have a suitable size and prevent the cards from scratching each other in my storage boxes...
Antistatic tape...total overload?
