First post, by sf78
So it has a Phoenix Bios 2.11 but no way to access it? I've tried all the shortcuts listed here:
http://www.informit.com/articles/article.aspx … 27188&seqNum=13
To no avail. I've also tried different setup and diagnostic programs (GSETUP etc. ) that freeze as soon as they start. You can see all the settings are really funky, starting from the clock. I know some of these setups are not meant for XT's, but I wanted to try them all the same. Most I get with all the key combinations tried is a text "DEBUGGER ROM V 1.4" and then it stands there.
Reply 1 of 2, by Jo22
Hi, I think I've found a manual. Maybe it provides a clue (not sure, haven''t really read it,
because scrolling through the PDF is too demanding for my current PC).
Reply 2 of 2, by sf78
Thanks! It shows there is an older version of the configuration utility which is what I probably need. I hope it is in one of the boxes I still haven't been able to pickup.
