First post, by W Gruffydd
I won't post them, unless I've genuinely tried to find them. I'll start with a blurb on what is and why I want it. The progress I've made will be listed as either Lead, File or Problem.
Diamond Monster Sound PCI (aka MX100)
One of the first PCI sound cards and progenitor of the mighty MX300. Looking for Windows 95 drivers from the year of its release, 1997. Why? It's for a 1997 build with period-correct hardware, firmware, and software.
Diamond Monster Sound Drivers [Wayback Archive, crawled February 11, 1998] // Driver version 1.05.16, 12/20/97
Taiwanese FTP // MS10516.EXE
I need a full to driver package from a previous year to use it!
  1. MS10516.EXE is upgrade-only; it requires an existing driver file to be installed. Confirmed by the readme on the FTP and my own installation attempts.
  2. MS10511.EXE, the nearest previous version on the FTP, is also upgrade-only.
  3. MS95101A.EXE, the earliest version on the FTP ("Release 1.01" of Monster Sound according to its readme), appears to an entire installation of DirectX (see Attachment 1). When searching for the driver, pointing Windows to any of the these unzipped folders yields no results.
75.95 KiB
Attachment 1 - MS95101A contents
edit: Solved!
Out of desperation, I tried MS95101B.EXE. It turns out that this file, also on the Taiwanese FTP but without a separate readme, contained the needed drivers (see Attachment 2).
100.15 KiB
Attachment 2 - A vs B
My list of wanted hardware
Reply 1 of 1, by W Gruffydd
Abit LX6 (Intel 440LX) Motherboard
Intel Chipset Software Installation Utility - Archived Releases [Wayback Archive, crawled November 27, 1999] // Driver version PV 3.3.0.2, Production Release, June 18, 1998 (thanks darry)
I need a driver from 1997!
  1. Wayback Archives all but confirm that Abit neither released LX chipset drivers nor hosted them on their website. Intel is the way to go.
  2. Intel lists drivers with lower version numbers that were released later. 😒
  3. Release Notes from infinst_3302 readme suggest that the version I need is between 3.0 and 3.1:[code]Version 1.0 is the initial release of Windows 95 Support for Intel
    Chipsets.
    Version 2.0 added support for 824403LX/EX components.
    Version 3.0 added the following:
    - support Intel 82433LX Pentium II Processor to AGP Controller
    for OSR2/OSR2.1 operating system
    - name string 82371AB changed to 82371AB/EB
    - [PCI_DRV_AddReg] components written to .INF file
    Version 3.1 added the following:
    - support for 440BX
    Version 3.2 added the follwoing:
    - name string change for LX/EX chipset
    Version 3.3.0.0 added the following:
    - support for 440GX[/code]
