Win3.11 - S3 Drivers
First post, by emendelson
The Windows 3.11 drivers linked in the Window 3.11 guide seem not to work with French and other versions of Windows 3.11. I found a set of drivers that seems to work perfectly here:
https://www.classicdosgames.com/drivers.html
Probably this is linked somewhere else also, but I thought it was worth mentioning. It saved me a lot of headaches in a project I'm working on.
Reply 1 of 2, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The 1.70.04 drivers are recommended; however, the guide links to what I guess is only the English driver. A search for "w3117004.zip" should turn up some places to grab the full package that supports English, French, and German.
