First post, by laatemsb
We have on old 80386 PC with msdos 6.22 running with a MDA video card.
on the PC is a program running with only green text, you can set some values in the program, also only text.
I want to make the program running in dos-box, on a modern machine, but I did not find any good setting. the program won't start at all.
Dosbox will hang as soon as i start the program.I tried different machine options.
there are no errors in de window of dosbox, so i don't know where to look or to set.
anyone any idea why the program does not start?
it is a mz execute file.
Reply 2 of 3, by Stiletto
Moved.
do the Fandango!" - Queen
Stiletto
Reply 3 of 3, by derSammler
And the program is..?
