First post, by feipoa
I was browsing on eBay this afternoon and noticed what looks to be a 9th and 12th week of 1998 for the SiS 496/497 chipset. I have attached the image.
I think it might be neat to keep a list of the latest known 486 chipset datecodes. This is the latest SiS 496 datecode I've seen. I've seen some early 1997 for UMC 8881/8886.
171.8 KiB
ALi M1487 / M1489 from 36th week 2005 and 18th week of 2006.
230.65 KiB
Reply 1 of 12, by CkRtech
Cool topic, feipoa. First one is for industrial automation?
That second board is certainly "SMD for you and me" - a far cry from early-mid 90s 486s
Displaced Gamers (YouTube) - DOS Gaming Aspect Ratio - 320x200 || The History of 240p || Dithering on the Sega Genesis with Composite Video
Reply 2 of 12, by dionb
I wonder if the "ESA" on the second one refers to an extended ISA bus, or to the European ESA space agency? Either way an intriguing board, with not just an ALi chipet from 2005/6, but also a BIOS datecode from 2000 and a bona fide (and standard) 3-pin CPU fan header, a PC speaker, not to mention the SMD all over the place and of course the IDE flash disk. Very surprising to see a Dallas RTC in the middle of all this modernity 😉
Reply 3 of 12, by feipoa
ESA is a brand for industrial motherboards: Electronic Solutions Associates. The point of the thread is to see how late the datecodes went with these 486 chipsets. This information could be of interest when ordering replacement chipsets, that is, you can specify a certain datecode range when ordering.
Reply 6 of 12, by Moogle!
http://www.dfi-itox.com/pages/support/mbd/486vpc/g486vpc.pdf The manual.
Just noticed this is a different model to the one posted earlier in the thread. Interesting. :p This thing has a problem. Ultima 6 misses notes when an OPL3 is used. My other 486 PCI board has the same issue.
Reply 9 of 12, by Moogle!
feipoa wrote:
To confirm, you have a VIA VT82C496 and VT82C505 chipset with a datecode of week 48, 1998?
The VT82C496G has 9848 and 82C505 has 9705. Sorry this took so long. Got busy this week. Those the industrial 486 MOBOs were made into the early 2000s. Check around on Ebay and looks at the datecodes.
Reply 10 of 12, by WJG6260
Sorry to revive such an old thread, but I figured I'd contribute this oddity.
Recently, I purchased this American Predator Corporation Predator 747. It has a Chips & Technologies F84041 chipset, and a date code of 9944.
Corvalent, which appears to be American Predatorpost-rebrand, sells this same board here. I have no clue if this listing is current, but seeing as it's meant for industrial applications, it may very well be. I wonder just how late the date codes on the chipsets they're using these days are; I can't imagine that Intel is still producing these under the Chips & Technologies name.
When I have some more time, I want to make a real post about this thing. It's pretty fast and yielded the highest scores I've ever seen on a VLB S3 864 paired with a DX4-100WB.
473.73 KiB
This photo is from the eBay seller who sold me this.
-Live Long and Prosper-
Feel free to check out my YouTube and Twitter!
Reply 11 of 12, by BitWrangler
Wild, design of board looks more like 93 or 94 maybe.
