First post, by JimmyBlack
I want to know which is the fastest, most stable and accurate color/effects wise build to run Carmageddon 3DFX. Currently using 0.74G from GOG with the latest nGlide 2.00, but I have some issues with it.
Like bad performance with rear view mirror, texture seams in some levels and sound problems. Even occasional invisible walls.
I've read tons of guides, tips, hints, tricks from all over the inet, but it's all no good. Nothing was ever helpful...
Reply 1 of 3, by gdjacobs
You could try these two:
DOSBox ECE (for Windows & Linux)
DOSBox-X branch
Keep an eye on this one as well, as it will likely get the 3dfx patches in the future:
DosBox-0.74-ES (SDL2)
No recommendations for any particular branch, although all three maintainers are active on Vogons and seem to be responsive to issues as well as generally nice blokes.
Reply 2 of 3, by JimmyBlack
Thanks but none of them run 3DFX the way it should be.
Reply 3 of 3, by gdjacobs
You're referring to their use of 3dfx -> OpenGL emulation?
