First post, by Estel Randir
I successfully installed & had this game running in DOSBox. Sound effects, music, etc all worked. Then I patched to the official patch 1.1. No music no matter what I tried. I downloaded the patch from multiple sites & installed fresh each time in case the patch was bad. Same results. No more music. Mounting the CD as a folder or mounting the .iso made no difference either (fix for DS2 CD music).
CD version of the game, DOSBox 0.74. Anyone else had this issue?
Reply 1 of 3, by Yesterplay80
ISO file type and CD music doesn't work, games with redbook audio have to be in .bin/.cue file formats for the music to work.
My full-featured DOSBox SVN builds for Windows & Linux: Vanilla DOSBox and DOSBox ECE (Google Drive Mirror)
Reply 2 of 3, by gdjacobs
Certainly cue files are required. Some DOSBox patches allow the use of ISO and non redbook audio files.
It is also possible to use a cuescheet in combination with an ISO and compressed audio tracks in OGG or MP3 format.
-- http://www.dosbox.com/wiki/IMGMOUNT#Note:_you … _Mixed_Mode_CDs
Reply 3 of 3, by KainXVIII
Dark Sun 1 does not have cd-audio music.
BTW GoG version already patched to 1.1 and music works fine (MT-32 emulation through Munt)
