First post, by jheronimus
- Oldbie
I'm looking to buy a Toshiba T5200 — I've found a fairly cheap one, but the seller can't test it properly. As of now, it starts up, but doesn't boot. It gives the following errors:
Keyboard failure
Keyboard clock line failure
512K base memory 00000K extended
Invalid configuration information — please run SETUP program
Strike the F1 key to continue, F2 to run the setup utility
So my biggest concern is that the keyboard controller might be damaged. However, I've had some ancient systems (like a 286, for example) that would produce similar errors if the BIOS configuration is wrong. I've asked the seller to at least try entering BIOS to check if the keyboard is working. Meanwhile I have some questions:
1) I can see from this teardown that the CPU and FPU are socketed. Can I upgrade the CPU from 386@20 (mine is a 5200, not a 5200/100) to Intel 386@33?
2) what kind of BIOS battery does it use? There is an external battery on the teardown photos, but it looks like a mod to me
3) it has a 1.44MB drive, but is it standard? Will an ordinary 1.44 drive fit/work in this machine?
4) are Conner drives IDE-compatible? Can I fit a regular 3.5 inch IDE drive in this machine?
5) is there any way to use an external keyboard?
