First post, by GabrielKnight123
I have been restoring a small size PC HP Pavilion 4403 and it is limited to two PCI and two ISA buses because of form factor and I was using the onboard VGA video but in some games there were lines going up and down so I use a PCI S3 trio64 video card and this fixed it but now if I use a game that needs some ems ram like in the line for config.sys "DEVICE=C:\DOS\EMM386.EXE 4096 RAM I=BOOO-B7FF" the 4096 RAM part disables accessing my D: drive in dos it says no such drive or specification but if I use "Noems" I can access it. Im using an 80 wire cable for my DVD drive setup as a master on the secondary IDE, and for dos 6.2:
Config.sys
DEVICEHIGH=C:\CDROM\OAKCDROM.SYS /D:mscd001
Autoexec.bat
LH C:\CDROM\MSCDEX.EXE /D:mscd001 /L:D
