First post, by maximus
About a year ago, I decided to start collecting benchmark results for various video cards using the following mid-spec Windows 98 machine:
Dell Dimension 4100
Intel 815E chipset
Pentium III 1000
256 MB PC-133 RAM
20 GB HDD
Many hours of benchmarking later, I'm finally ready to share the results. I'm posting the most interesting graphs below, but this represents only a small fraction of the data I collected. I also have results for 640x480 and 800x600, as well as 16-bit color. I've published the full results on my website, along with analysis and details of the hardware, software, and methodology used:
Windows 98 VGA Charts - PCGames9505
pubchart?oid=327655779&format=image
pubchart?oid=1076882992&format=image
pubchart?oid=1633283799&format=image
pubchart?oid=360549122&format=image
pubchart?oid=730969476&format=image
pubchart?oid=1793727078&format=image
pubchart?oid=1765917677&format=image
A note on the cards:
I thought it would be interesting to test newer, more advanced, low-end video cards against older, less advanced, high-end ones, so I chose cards with this goal in mind. More generally, I also chose cards with low-ish power requirements and good Windows 98 driver support. I don't know if the test system's power supply could handle a GeForce Ti 4600, GeForce FX 5950 Ultra, GeForce 6800 Ultra, or Radeon 9800 Pro, so I left these cards out. (They would all be severely bottlenecked by the Pentium III anyway.) I also got into collecting too late to score many 3dfx cards for good prices, which is why the Voodoo2 and Voodoo5 5500 are not on the charts, and probably never will be.
PCGames9505
Reply 1 of 11, by MMaximus
Thanks for doing this. How come the voodoo 3 3000 shows "0" in all the results though? I have one in my PIII rig and am curious about how it compares to the rest of the bunch...
Hard Disk Sounds
Reply 2 of 11, by clueless1
Because he's only showing results at 32bpp. 🙁
OP - thank you for posting this. I will go to your site to check the rest of the results. When results take months (let alone a year) to collect, I always give the utmost respect. Cheers, and thanks!
Reply 3 of 11, by RogueTrip2012
Great work. I'm surprised by the mx440 beating a GeForce 3!
If I lived closer I'd loan you my cards for testing. No way I got time for that testing.
> W98SE . P3 1.4S . 512MB . Q.FX3K . SB Live! . 64GB SSD
>WXP/W8.1 . AMD 960T . 8GB . GTX285 . SB X-Fi . 128GB SSD
> Win XI . i7 12700k . 32GB . GTX1070TI . 512GB NVME
Reply 5 of 11, by CkRtech
Thanks for doing this and sharing it with the community. We greatly benefit from the blood, sweat, tears, and time that goes into this endeavor.
Displaced Gamers (YouTube) - DOS Gaming Aspect Ratio - 320x200 || The History of 240p || Dithering on the Sega Genesis with Composite Video
Reply 6 of 11, by Srandista
Thank you for nice set of tests. Just few notes from my side.
In Unreal Benchmark, you probably have a mistake, with resolution 640x480x32, you probably meant x32, not x16: "Enabling 32-bit color in Unreal Gold causes a significant performance drop across the board, even at 640x480x16."
And it's pity, that you tested all ATI cards with 6.2 driver, as it seams, that on slower HW, it's driver with highest overhead, at least according to testing of this fellow Vogoner: ATI Radeon 9800 Pro, quick test.. The 6.2 version is only needed for 9550.
And also, it's too bad, that you don't have Radeon 9500 instead of 9550. That card it's real underdog in my eyes, since if you have right version (non-Pro with 128MB RAM), then that card its having 256-bit memory bus width (not 128-bit, as Wikipedia suggest), and also with some luck can be unlocked by Softmod into full blown 9700, and with a bit overclock even surpass 9700 Pro.
But other then that, I give you my highest respect for your dedication during the testing!
Reply 7 of 11, by maximus
Fixed. Good catch!
Catalyst 6.2 does seem to have an awful lot of overhead. If I ever revisit any of the ATI cards, I'll have to try some of the older drivers and see what kind of impact they have on the benchmarks. I hear bad things about older ATI drivers, though, so I wonder if I'd just be trading high overhead for bugs. 😒
I'm definitely looking to acquire more R300-based cards. While the Radeon 9550 wasn't the fastest card I tested for this project, it did have the unique ability to enable 4x AA and 8x AF with virtually no performance cost. (Not the case for the GeForce 6200!) Driver compatibility was damn near perfect, too. I can imagine that the mid-range R300 cards would be quite nice to have for Windows 98 gaming.
PCGames9505
Reply 8 of 11, by maximus
firage wrote:
Always lovely to see the MX440 do well.
The GeForce4 MX440 is pretty much my favorite Windows 98 card. It's as fast as the GeForce2 Ultra (sometimes faster) and doesn't have the wavy horizontal lines problem (discussed here). The GeForce3 beats the MX440 in some tests, but it has the blurry font problem in Need for Speed: Porsche Unleashed, which is basically a deal breaker for me.
If I could only have one video card for Windows 98 gaming, it would probably be a GeForce4 MX440 or something similar (MX460, Quadro4 380XGL).
PCGames9505
Reply 9 of 11, by maximus
Thanks to everyone who's responded so far. It's good to know that other people find value in this kind of stuff. If I ever get the urge to embark on another benchmarking project, I'll be sure to share the results here.
PCGames9505
Reply 10 of 11, by KCompRoom2000
If you're still having trouble finding older ATI drivers, here's a place that may help (scroll all the way down to the bottom of the page on that link for the older 9x-compatible drivers: http://www.oldapps.com/ati.php
I use Catalyst 3.1, so that version may be worth a shot to try on your Radeon 8500 and 7500.
Reply 11 of 11, by The Serpent Rider
That's because all this tests does not include trilinear filtering.
