First post, by Scubs
. I wanted to upgrade the cpu, right now it has an via cpu board that suports via c3's and tualatin Piii.
Unable to find a faster 1.2ghz or 1.4ghz c3 and not wanting a Piii, was their ever any socket A picmg 1.0 cpu boards made? I personally can't find any.
Reply 1 of 3, by cyclone3d
Found one:
http://www.voxtechnologies.com/industrial-pc- … e-sbc/rocky-772
The only other option would be a Pentium IV, which could get you up to 3.06 or 3.2Ghz depending on the chipset and BIOS.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 3, by Scubs
Thanks!
Sadly rocky boards are far from cheap and abundant.
Stupid question, would Ilose dma with such a board.
But I rather not use a p4. To much heat and the weight from the heatsink scares me.
Reply 3 of 3, by cyclone3d
Scubs wrote:
Thanks! Sadly rocky boards are far from cheap and abundant. Stupid question, would Ilose dma with such a board. […]
Thanks!
You shouldn't lose DMA. The bus speed indicates that it is one of the older chipsets (200/266 clock doubled bus speed) which means it should have DMA.
Even the older Socket 478 PICMG boards can have DMA.
Just double check the spec sheets / instruction manuals.
YMF7x4 Guide
